Wireless Controller 4404 - 4 Uplinks
Jun 24th, 2009
Hello! I have a wireless controller 4404, running code. I have LAG enabled but currently have only 2 ports used, I am planning on connnecting the other two ports soon. Will this cause an outage? I am thinking no, but I want to see if anyone has ever done this and what the outcome was. Thank you.
Leo Laohoo Wed, 06/24/2009 - 16:25
Are you plugging the last 2 uplinks to the same switch?
Just make sure that STP is DISABLED and it should be fine.
jcerero77 Thu, 06/25/2009 - 07:54
Yes I am plugging the last two uplinks to the same switch, but on a different module. When you say make sure that STP is disabled, what are you referring to? Spanning-tree portfast?
dancampb Fri, 06/26/2009 - 04:40
Also make sure you create an ap-manager interface for every active port on the controller.
mat.edwards Sat, 06/27/2009 - 11:39
LAG is enabled so there will only be one AP Manager interface. No requirement/ability to create additional interfaces.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
