Migration questions unity
Answered Question
Jun 24th, 2009
Is it possible to migrate users voice recordings from unity to unity connection ? also if using unity version 5 and migrating to a new server platform running unity version 7 can cobras be used to move user recordings.
Correct Answer by Rob Huffman about 7 years 11 months ago
Hey Dave,
Long time, hope all is well!
Here is the COBRAS Compatibility;
Unity Export works with Unity 4.0(5), 4.1(x), 4.2(x), 5.0(x), and 7.0(x) with Exchange or Domino.
Connection 1.2 Export is only 1.2, no 1.1 support.
Connection 7.0 Export works with any version of 7.0(1) or later, however for message extraction to work 7.0(2) is required.
**Any Unity export can be imported on any Unity version running with Exchange that's the same version of Unity or later. **Any Unity export of any version can also be imported onto Connection 7.0. A Connection export, however, can NOT be imported into any version of Unity. See the help for more details
NOTE: there will be no import or export for Unity Connection 2.0 or 2.1 since the off box access necessary for these tools was not present in those releases.
NOTE: Imports onto Connection 7.x and later are only supported for stand alone installations, no support for co-resident installs (Business Edition). You can export from a co-resident install, but not import.
NOTE: No imports onto Domino based Unity systems are supported and there are no plans to support this moving forward.
http://www.ciscounitytools.com/App_COBRAS.htm
COBRAS Gets Most Data For:
Call Handlers
Subscribers (optionally including messages)
Interview Handlers (a.k.a. Interviewers)
Public Distribution Lists (optionally including membership information)
Schedules
Routing rules (for restores onto Unity servers only)
COBRAS Does Not Get:
Class of Service
Restriction tables
Name Lookup Handlers (a.k.a. Directory Handlers)
Locations
Contacts (includes SMTP/AMIS/Bridge/VPIM subscribers)
Holidays
System configuration data such as switch configuration, LDAP integration details, IMAP login data, RSA configuration, advanced settings etc..
Subscriber templates
Password policy information
Secure (encrypted) messages. If you've selected to backup messages for subscribers on Unity, secure messages will not be included. If only part of the message is secure (such as a forwarded message with introduction) then that message part will not be playable when restored to another server.
http://www.ciscounitytools.com/Applications/COBRAS/Help/COBRAS.htm#_Toc213300677
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 06/24/2009 - 10:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Dave,
Call Handlers
Schedules
Class of Service
Restriction tables
Locations
Holidays
Hope this helps!
Rob
