06-24-2009 09:56 AM
1) Can the WAVE-274-K9 device be configured as a WAAS Central Manager off-the-shelf ?
2) Same for WAE-512-K9 device ?
regards,
Geert
06-24-2009 01:15 PM
Geert,
For the CM functionality in WAAS 4.1.x, you need the enterprise license installed, then you can configure the CM role on the device.
274 can support around 125 WAEs
512-1GB can support 500 WAEs
512-2GB can support 1000 WAEs.
Hope that helps,
Dan
06-24-2009 01:21 PM
Thanks Dan.
Only thing is: the WAVE comes with Enterprise license by default (for a very good price). For the WAE, it needs to be added seperatly.
07-27-2009 09:26 AM
can you send me any document where you found it?
"274 can support around 125 WAEs
512-2GB can support 1000 WAEs. "
Thanks a lot,
