Bad behaviour phone 7961
Jun 24th, 2009
hi,
i have strange bahaviour with phone 7961.
this phone is registred with subscriberand it can make calls.
but this phone had 175 as directory number and i can't change this DN and the phone doesn't respond to reset and restart, but the other phone 7941 and 7911 work fine.
i have deleted this phone and regestred him manually again but always memorize the same config.
i restart the call manager ( cluster 6.1 in 2 mcs 7816) but no result.
no idea ?
please help or advice?
thanks in advance
bsaid1977 Wed, 06/24/2009 - 14:02
after resetting the phone to factory defaults, the phone passed the process of upgrade , the phone still have the same conf (DN:157).
the replication works good, all changes made in publisher , the subscriber have the same info.
david-lima Thu, 06/25/2009 - 11:01
  • Bronze, 100 points or more
Hi friend, try this.
Unplug the phone, then delete the record from device->phone. Finally use the Route Plan Report to delete unassigned directory numbers in Call Routing->Route Plan Report.
Because when a directory number gets removed from a device or a phone gets deleted, the directory number still exists in the CUCM database. To delete the directory number from the database, use the Route Plan Report window.
Hope this help
David.
