rfc 1483 killing idle tcp connections
Jun 24th, 2009
  • Bronze, 100 points or more
My idle tcp connections are dropping at inconsistent times. The connections are telnet and can be idle from 5 mins to 1hr.
This is over a vpn connection using VPN -rfc 1483 bridging. I'm only having this trouble with the locations configured as such and the pppoe connections are fine.
I was thinking about implementing ip inspection and forcing the idle_timers, if possible.
