Proxy Server
Jun 24th, 2009
  • Blue, 1500 points or more
Hello All,
I have a 6500 and an ASA installed. I need to proxy http traffic to a 3rd party Web filter before it hits the ASA. How do i accomplish this? Do i use WCCP? If so, what version?
G
Giuseppe Larosa Wed, 06/24/2009 - 22:03
  • Hall of Fame,
    Founding Member
Hello George,
you can use WCCP2 for this if supported on that 3party device.
WCCP any version implies a communication between web cache(s) and router(s)
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/wccp.html
if this is not your case you can use PBR.
Hope to help
Giuseppe
George Thomas Thu, 06/25/2009 - 05:27
Hi Giuseppe,
Thanks a lot for the response. The 3rd party device is a Web filter that doesnt support WCCP. I think I will have to fo the PBR route. Where do I have to set the route-map policy? Is it on the firewall VLAN interface or on all VLAN's where I have clients connected?
Thanks a lot for your help.
G
Giuseppe Larosa Thu, 06/25/2009 - 05:43
  • Hall of Fame,
    Founding Member
Hello George,
PBR has to be applied inbound so you need it on the internal interfaces where traffic originated by clients is received.
The web filter/cache has to be reachable through a separate L3 interface
Hope to help
Giuseppe
George Thomas Thu, 06/25/2009 - 06:30
Hi Giuseppe,
If I understand this right, I will have to put the policy map on each and every VLAN and the IP address of the web filter should be on a different VLAN, correct?
G
