a few questions on the ACE
Jun 24th, 2009
I am getting up to speed on the ACE and was wondering if someone could please clarify a couple of things for me as the docs I am using are pretty confusing.
We have the ACE module in a Cisco 65XX switch, along with FWSM.
1) Do I need to create a Layer 3 int on the switch for the Vlan's that I have assigned to the ACE?
2) I have created a Layer 3 Client side and a Server side Vlans on the ACE. Do I need to create a default gateway for each of these Vlan's or create just one DG and point it to the switch?
3)Do I need to create a class map, a policy map and a service policy for the Client and Server Vlan L3 interfaces on the ACE?
Thanks much.
Gilles Dufour Wed, 06/24/2009 - 23:52
you don't need an interface on the MSFC unless you want to use it as a gateway for the ACE. You could also use the FWSM as DG in which case you don't need an interface on the MSFC.
Only 1 DG is enough.
Class-map/policy-map and service policy are the instructions to tell ACE what to do.
If you do not use configure any, ACE is just a router.
So, depending on what you want to do, you will need to configure something.
