How do I assign a static internal IP in a RV042 router
Jun 24th, 2009
Hi, How can I configure(in the router) an specific static internal IP address for instance ( to an specific computer on my LAN? Is it enough to assign the static IP address in the computer only? My goal is to set this IP statically for Port Forwarding. I want to know as well how to setup (in a secure way) the remote administration of the router. Thank you
salciscousr Thu, 06/25/2009 - 19:42
Hi, thank you for your answer, but the link you sent me did not work. How can I get to that "Routers section of the Small Business Support Community"?
