Custom UDP service timeout
Jun 24th, 2009
I don't want to change the global UDP idle timeout for the entire firewall for obvious security reasons but I have to change timeout for a particular UDP port from a known source IP to another known destination IP. I tried using:
object-group service blah
timeout udp 0:20:00
or timeout udp 0:20:00 conn 1:00:00
but the timeout command does not stay in the config. I even tried MPF but MPF doesn't have UDP option or I can't find it.
Is there another way?
Thanks in advance
Patrick0711 Wed, 06/24/2009 - 20:30
I did something similar for TCP connections the other day...
This should work...substitute the TCP for UDP and add the necessary UDP port in the ACL:
access-list custom_timeout extended permit tcp host any
class-map custom_timeout
description Connection Timeout for specific hosts - 3 hours
match access-list custom_timeout
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
class custom_timeout
set connection timeout tcp 03:0:00 reset
ned.tavakol Thu, 06/25/2009 - 01:39
Thanks for your respond.
I've already tried this but unfortunately there isn't a udp option with this method.
please see below
hostname(config-pmap-c)# set connection timeout ?
mpf-policy-map-class mode commands/options:
dcd Configure dead-connection-detection retry interval.
embryonic Configure absolute time after which an embryonic TCP connection
will be closed, default is 0:00:30.
half-closed Configure idle time after which a TCP half-closed connection
will be freed, default is 0:10:00
tcp Configure idle time after which a TCP connection state will be
closed, default is 1:00:00
ned.tavakol Sun, 02/19/2012 - 16:36
The custom UDP service was taken out of ASA 8.x code and by request it was added back in higher releases of 8.2
