06-24-2009 06:10 PM - edited 03-11-2019 08:47 AM
I have an ASA5505 configured for Remote VPN connection. I am adding an IP phone server that will allow remote IP phones to connect to the internal phone system. I need to Port Forward port 59002 to an internal IP address. Is there an easy way to do this? Thanks, Kevin
06-25-2009 01:43 AM
Kevin,
Is the IP phone software or hardware based?
06-25-2009 05:37 AM
Andrew,
I believe it is hardware based because I have an actual phone as a remote and a computer inside my network. It is an ESI 50 system.
Kevin
06-25-2009 05:47 AM
Just add an entry to the acl allowing any remote access to the NAT ip using a desintaiton TCP/UDP port required.
06-25-2009 06:01 AM
Can you give me the entry for that? I have added a couple of access-list commands and static commands to the configuration. I can see the static entry in the NAT using ASDM showing the port on the outside and the IP on the inside but it still does not work.
06-25-2009 02:38 AM
you just need to allow the port on the ACL on your remote user policy group.
06-25-2009 05:46 AM
Francisco,
This remote phone does not use the remote VPN connection. I think it just uses our public IP and port. With the port forwarded to the IP of the ESI computer on the inside of the network.
Kevin
06-25-2009 05:53 AM
Static (INSIDE,OUTSIDE) tcp interface 59002
Access-list
06-25-2009 06:02 AM
I just gave you the commands
06-25-2009 06:09 AM
I see that now thanks! Please forgive me, I am not an IT professional, just a small business owner trying to survive. Can you give me an example of the
06-25-2009 06:14 AM
Access-list ACL_OUT permit tcp/udp ANY
access-group ACL_OUT in interface OUTSIDE.
If you hace any problem please send me the
show run access-group
show access-list
06-25-2009 06:24 AM
When I type in the access-list command, I get the error Invalid Hostname with the indication on the "e" of eq.
06-25-2009 06:54 AM
Success!! I added the word "host" before the public IP and then followed the rest of the commands. The phone works! Thanks!!!!
06-25-2009 07:00 AM
Very Welcome have a good one
