UC520 as h323 Gateway and CME simultaneously
Paolo Bevilacqua Wed, 06/24/2009 - 23:30
  • Hall of Fame,
    Founding Member
Yes, it is no problem.
However since the datasheet says CUCM is not supported, the TAC will not support you on that aspect.
kelvin.blair Thu, 06/25/2009 - 11:49
  • Silver, 250 points or more
That is correct. TAC will not support this type of configuration. All you need to do to accomplish is set the UC520 up as an H323 gateway in CUCM and configure your voip dialpeers on your UC520 to point to the CUCM.
Paolo Bevilacqua Tue, 06/30/2009 - 04:31
  • Hall of Fame,
    Founding Member
ephone-dn xx
call-forward all
However if you're just trying to integrate CUE to CUCME, just do that directly.
Paolo Bevilacqua Wed, 07/01/2009 - 01:49
  • Hall of Fame,
    Founding Member
As H.323 GW is enough, then you configure some route pattern to use it.
