CME and B-ACD
Answered Question
Jun 25th, 2009
I am looking to use B-ACD on a CME 7.1 box using Longest IDLE. How and where can you set up log in ID's for the agents or can you not do this. I keep seeing info stating that you can log in/out of a que but no info on end user or admin programming of this.
Correct Answer by paolo bevilacqua about 7 years 10 months ago
It's all explained in the administration guide.
You define hunt-group logout under telephony-service, and define hlog softkey in ephone-template.
Overall Rating: 4 (1 ratings)
Correct Answer
paolo bevilacqua Thu, 06/25/2009 - 04:41
  • Hall of Fame,
    Founding Member
