Upgrade hung on "CUE Install License"
Jun 25th, 2009
Hello, I am trying to upgrade my UC520 to 7.0.3 upgrade package using CCA 2.0. Everything seemed to be going fine until it got to 67% and said "CUE Install License". It's now been sitting there for an hour. Has the upgrade gone wrong? Can I cancel and and try again without being left with a doorstop?
Skyler Spence Thu, 06/25/2009 - 07:40
You can certainly cancel the upgrade and retry.  I would suggest checking the current status of your CUE module on the UC500 before attempting the upgrade again.  To do this, telnet to the device at its Data LAN IP address, default is 192.168.10.1.  Enter your administrator login information, then type
service int 0/0 status
And check that the module is up and responsive.  Then try the upgrade again and post here your results.
mfleming Mon, 06/29/2009 - 03:54
Hi Skyler
That command produces:
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Cisco Unity Express 7.0.3
CUE running on UC500
Does this mean the update completed successuly? I tried the upgrade again anyway and it is failed on CUE backup and the status message tells me that it can not back it up. Should I go back to blank flash with IOS only and try again?
Skyler Spence Mon, 06/29/2009 - 07:44
7.0.3 is certainly the version of CUE used in this software pack, which software pack were you upgrading from?  This could mean that CUE was upgraded successfully that first time.  As for the current problem, past experience has been that backups fail due to personal firewalls, multiple simultaneous network connections, or ftp servers running in the background.  Check for these conditions, you may also try manually peforming the backup using the backup/restore tool located in the CUE web pages (default http://10.1.10.1)
mfleming Tue, 06/30/2009 - 05:06
Hi Skyler
I was trying to upgrade from 7.0.2 I think? In the end I formatted the flash card and followed the complete manual upgrade procedure and the system is now functioning correctly.
