portforward on asa 5505
Jun 25th, 2009
Hello, i have a problem setting up portforwarding on a asa 5505
I want to get tcp port 2051 on the outside to be forwarded to 192.168.6.10 on the inside and i have the following config:
ASA Version 7.2(4)
interface Vlan1
nameif inside
security-level 100
ip address 192.168.6.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 195.81.121.246 255.255.255.252
interface Ethernet0/0
switchport access vlan 2
access-list inside_nat0_outbound extended permit ip any any
access-list inside_nat0_outbound extended permit ip 192.168.6.0 255.255.255.0 any
access-list outside_access_in extended permit ip any interface outside
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 2051 192.168.6.10 2051 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 195.81.121.245 1
dhcpd auto_config outside
dhcpd address 192.168.6.90-192.168.6.99 inside
dhcpd dns 192.168.6.1 interface inside
dhcpd enable inside
It seems that is constantly blocked by an ACL but i can't figure out the right config, could you give me some input?
Overall Rating: 1 (1 ratings)
dcambron Thu, 06/25/2009 - 05:58
  • Cisco Employee,
static (INSIDE,OUTSIDE) tcp interface 2051 192.168.6.10 2051
no access-list outside_access_in extended permit ip any interface outside
access-list outside_access_in extended permit tcp any host 195.81.121.246 eq 2051
access-group outside_access_in in interface OUTSIDE
let meknow if it works
ciscoadminist Wed, 07/22/2009 - 09:01
access-list outside_access_in extended permit ip any any
tray that's, it's work for me.
Good luck
alexojeda Thu, 07/16/2009 - 19:24
down the security level at Vlan1
from 100 to a low.
example: 90
