Radius Server
Jun 25th, 2009
We have been getting this alarm in WCS:
Radius server '192.168.100.219'(port 1813) is deactivated.
I checked and everything and it looks fine , the radius server is still shows enable and functional.
Any idea what could this be??
THank you
Vic
ericgarnel Fri, 06/26/2009 - 06:41
  • Gold, 750 points or more
1813 radius accounting port
Are you using 1812-1813 for radius or 1645 & 1646?
So the auth is working but not accounting
what port do you have configured on the WLCs
listed under
SECURITY, AAA | RADIUS | Accounting?
Victor Fabian Fri, 06/26/2009 - 07:25
i asked a wireless cisco engineer and he told me that this setting is ok.
This is the way i have it setup:
Authentication
10.138.10.26 1812 enable
10.138.15.129 1812 enable
accounting
10.138.10.26 1813 enable
10.138.15.129 1813 enable
Is it ok for both server to have the same port number ??
THank you
Vic
ericgarnel Fri, 06/26/2009 - 07:33
So you have 2 servers that do auth & acct, I notice that the error has a different ip address of 192.168.100.219. Your radius is working fine because the .26 & .129 servers are handling it. Where is 192.168.100.219
jicr Fri, 06/26/2009 - 09:39
Whether your clients are authenticating properly???
This message comes from a different IP address which is not configured on your controller. Even i observed like it is coming on port 1813 which is normally used for accounting so your client authentication wont interrupted.
Can you check the o/p of debug command
"debug aaa events enable" this will give you a perfect idea of wht is happening
Victor Fabian Fri, 06/26/2009 - 11:46
Sorry about that but my colleague didn't put the real ip address and he just enter a bogus one for the first posting but for the last post those are the real ones.
thank you
Vic
ericgarnel Fri, 06/26/2009 - 11:52
So are you getting the error message for both radius servers then? if not, would start looking at the suspect radius server and/or network path between the source & destination
Scott Fella Sun, 06/28/2009 - 06:55
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Are you seeing any errors on the radius server logs. It can be an issue with the shared secret. Do you see the error pointing to both radius servers or just one. If you see this on both, you shouldn't have any users connecting. Verify the shared secret and if you are using a 63 characters, then enter the shared secret on the cli of the WLC.
Trending Topics - Security & Network
