question about transport input command
nygenxny123
transport input telnet
will only allow telnet
transport input ssh
will allow only ssh
transport input telnet ssh
will only allow telnet and ssh
what will the default do?
as opposed to the transport input all?
Richard,
You are indeed correct. That section of the documentation needs to be updated. It does mention in the 'Usage Guidelines' that the default 'none' applies to TTY connections but there is no mention of VTY connections.
I did a little digging and it seems the VTY connections default is set to 'all' but the documentation makes no mention of it.
__
Edison.
Edison Ortiz
is the default dependant on the IOS?
this is the running config from a cat switch.
it appears to be at default..
but if it was none, i shouldn't be able to telnet ..right?
line con 0
privilege level 15
line vty 0 4
privilege level 15
line vty 5 15
privilege level 15
yet i can telnet to it,
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
Richard,
__
Edison.
great thx!!
