H.323 Gateway
Jun 25th, 2009
Hello All,
on a 2821 router running CME 7.x with a PRI coming in can we do something like an H.323 bridge that sends certain DIDs over the network to another IP enabled device? The goal is to get certain calls from the PRI to another phone system.
Thakns in advance! All replies rated
Overall Rating: 5 (1 ratings)
kelvin.blair Thu, 06/25/2009 - 07:00
This is very much possible. I've done it multiple times, but it really depends on what the other device is to really know how to integrate with it.
What will you be sending the calls to? Also, look at this SRND guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/multcme.html
I know that it references multiple CME devices, but the integration to other systems is similar.
