Mangement design for DMZ switches
I'm trying to decide the best route for managing devices on the other side of a firewall. Is it best to open up ports for SNMP to a management IP address on a switch, or can I connect an 2811 with a NM-16A and octal-async cables to the console ports of the switches. If I do that can I send SNMP out the console port?
mmacdonald70 Sun, 06/28/2009 - 16:43
The console port is for serial communication only. If you require SNMP you will need to use IP.
Use V3 and restrict access to your IP address
