How configure siemens hipath SIP trunk
Jun 25th, 2009
hi all
i wish know how configure SIP trunk with Siemens hipath 4000, some example configuration or way.
silver.markus Thu, 06/25/2009 - 07:19
Configure the SIP trunk on the Siemens itself or on a Cisco device, such as CME or CM?
eljose_lol Thu, 06/25/2009 - 10:18
hi, i need to know how configure in Cisco Call Manager 5.1 with Siemens Hipath 4000 via SIP trunk, without using E1 QSing.
kelvin.blair Thu, 06/25/2009 - 11:03
I would not recommend doing a direct SIP trunk from CM to the Hipath. You will be really limited to what you can do with it. Your best bet is to use a CUBE to interface between the two systems. However, QSIG is the recommend integration type of a Siemens PBX. Here is one document that may help.
Here is another link that may be useful.;jsessionid=574712FBC179928F2D521F7FB506F30F.node0
eljose_lol Thu, 06/25/2009 - 12:20
Hi, thanks for the reply, but using E1 controller i will limited for 30 calls only, maybe 15 in / 15 out, and that's not good for me. i have more than 500 Ip phones in both sides, (Siemens and CCM).
i hope you can help me.
