Generate Translation Pattern Report or view in SQL table
Answered Question
Jun 25th, 2009
Is there a way to generate a translation pattern report. I do not want to have to do it manually as I have a high volume of patterns. I have tried Route Plan Report but this did not help. I am now looking through the SQL tables but have not found this yet. I have Callmanager 4.1.3
Correct Answer by Jaime Valencia about 7 years 9 months ago
Only thru SQL, there is no reporting on that via CCMadmin, BAT, etc
Look at NumPlan Table, reference value for TypePatternUsage to get translations.
java
if this helps, please rate
Overall Rating: 3 (1 ratings)
Correct Answer
Jaime Valencia Thu, 06/25/2009 - 08:06
  • Cisco Employee,
  • Hall of Fame,
    2011
java
