SIP Account
Jun 25th, 2009
I have a CME 7.0 on a Cisco 2811 router.
I configured an SIP account with more numer on the same username and password and URI.
The configuration is:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
h323
no h225 timeout keepalive
call preserve limit-media-detection
modem passthrough nse codec g711alaw
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
registrar server
voice translation-rule 2
rule 1 /^0\(.*\)/ /\1/
voice translation-rule 3
rule 1 /^.*/ /5353188/
voice translation-rule 4
rule 1 /5949030890/ /999/
rule 2 /5353188/ /999/
rule 15 /^.*/ /999/
voice translation-rule 5
rule 1 /5949030891/ /999/
rule 2 /5949030890/ /100/
rule 3 /5353188/ /100/
rule 15 /^.*/ /100/
voice translation-profile PSTN_Incomming_Acetaia
translate called 5
voice translation-profile PSTN_Incomming_GCREM
translate called 4
voice translation-profile PSTN_Outgoing
translate calling 3
translate called 2
dial-peer voice 20 voip
description Chiamate verso Sip
translation-profile outgoing PSTN_Outgoing
destination-pattern 0T
redirect ip2ip
rtp payload-type cisco-codec-fax-ind 102
rtp payload-type nte 96
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
no vad
dial-peer voice 21 voip
description Chiamate entranti da Sip per GCREM
translation-profile incoming PSTN_Incomming_GCREM
redirect ip2ip
voice-class codec 1
incoming called-number 5949030890
dtmf-relay rtp-nte
no vad
dial-peer voice 22 voip
description Chiamate entranti da Sip per Acetaia
translation-profile incoming PSTN_Incomming_Acetaia
redirect ip2ip
voice-class codec 1
incoming called-number 5949030891
dtmf-relay rtp-nte
no vad
sip-ua
credentials username 5353188 password 7 15151E180124222D realm sip.messagenet.it
authentication username 535XXXX password 7 10491C0D00191B02
retry invite 4
retry response 3
retry bye 2
retry cancel 2
registrar ipv4:212.97.59.76:5060 expires 3600 sip-server ipv4:212.97.59.76:5060
show sip-ua register status
Line peer expires(sec) registered
5353188 -1 2115 yes
I can call with both the numbers on the same SIP account.
I need to ring one Ip-phone in the case the number called is 5949030890 an other IP-Phone in case the number called is 5949030891.
In attach you can find the debug output of:
debug voice dialpeer detail
debug voice dialpeer inout
debug voice translation
How can I make this work?
bwalchez Wed, 07/01/2009 - 13:25
Try to use the voice translation rule:
voice translation-rule xx
rule 1 /^[+]\(.*\)/ /\1/
alex.sintoni Wed, 07/01/2009 - 23:39
Thank you for your reply, but this translation-rule didn't match anything.
