Can't change default gateway manually on 7912
Answered Question
Jun 25th, 2009
hi everyone
i need to change the default gateway manually on ip phone 7912, but i cant becouse they download that configuration from dhcp server. i cant change the dhcp values. is any way to change manually in the ip phone from menu or other way ?, the menu dont have the edit option.
Correct Answer by david-lima about 7 years 8 months ago
Hi friend, you need to disable first the DCHP Option (settings->dhcp enabled=NO, to unlock the option press **#) and then you will be able to configure the IP,MASK TFTP, default gateway, etc.
All the best
David
Overall Rating: 5 (1 ratings)
Correct Answer
david-lima Thu, 06/25/2009 - 14:30
All the best
David
