history buffer
Answered Question
Jun 25th, 2009
  • Bronze, 100 points or more
hi every body!
My book shows following commands:
history size x (line configuration mode)
terminal size X ( exec mode)
If both commands set to diffirent number, which one will take precedence?
Thanks a lot!
Correct Answer by Edison Ortiz about 7 years 11 months ago
I believe you are comparing history size and terminal history size.
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_f1.html#wp1016413
The history size will affect any connections made to that line while the terminal history size will only affect the current session. Once that session disconnects it will revert back to the default.
The terminal history size will change the size during that session so it overrides any history size setting for that session.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Thu, 06/25/2009 - 09:12
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
