1+1 Port Protection on OC-n on ONS-15454
Jun 25th, 2009
I have a delima. When we setup the 1+1 protection, one node was a at Ver. 6.x and the other node was at ver 4.x and there were two different entities were doing the provisioning. The provisioning ended up being crossed over, no APS invalid errors came up until we U/G to Ver. 8.5. I have traffic provisioned on what is my Working side. Is there a way to reprovision the 1+1 without deleting the traffic? Or will I need to just move the fibers?
viyuan700 Thu, 06/25/2009 - 11:24
  • Silver, 250 points or more
in 1+1 protection, the same signal flow through both fiber simultaneouly but only one is slected at receive end. So you can force your protection to work on one side then you can make necessary changes to the other side and then repeat the process once again to make changes to the side it was working.
