BAT - UDP Template Speed Dials
Jun 25th, 2009
Hi, I am running CUCM7 and have created a Cisco 7960 UDP Template and assigned a speed dial to button 6.
When I import UDP users and use this template, the import is successfully, but when I view the created UDP, the speed dial I have created has moved to button 3 (the first available speed dial button), any ideas why this is?
Rob Huffman Fri, 06/26/2009 - 04:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ian,
It sounds like you are hitting this bug;
CSCsr04980 Bug Details
CCMAdmin UDP Template Button Template in wrong order with blank items
Symptom:
UDP Template - Button Template will show buttons in incorrect order if there are blank items before populated items of the same type.
For instance:
Line 1 - SURL - left blank
Line 2 - SURL - populated with a service
will get translated to
Line 1 - SURL - populated with a service
Line 2 - SURL - left blank
Conditions:
Using UDP Templates under Bulk Administration on CUCM 5.X and 6.X
Workaround:
Enter populated items first and leave blank items last.
Use the None button item to preserve spacing between items Status
Fixed
Severity
3 - moderate
Last Modified
In Last month
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
6.1(2)
Fixed-In
6.1(2.9901.105)
7.0(0.39700.171)
7.0(0.66666.1)
7.0(0.66666.2)
7.1(0.98999.7)
6.1(3.1000.16)
6.1(3.9999.1)
7.1(2.10000.16)
Hope this helps!
Rob
ian.ryder Fri, 06/26/2009 - 05:10
Excellent, thanks Rob.
How did you find this, I searched the bug toolkit for UDP Template Button Template in wrong order and recieve no results, but when I input the CSCsr04980 I get this response back....
Rob Huffman Fri, 06/26/2009 - 05:28
  • Hall of Fame,
    Founding Member
Hi Ian,
You are most welcome my friend! Sometimes, "less is more" when it comes to the Bug Toolkit ;-)
For this search I just used UDP as the "keyword" and CUCM 7.0 as the Product Search. The Bug Toolkit is like an Archeological dig at times.
Hope this helps!
Rob
