ISDN BRI Backup
Jun 25th, 2009
Does any body are already configure a ISDN BRI Interface as backup line for Serial connection?
I have two site that must be connect with ISDN BRI whe the main serial ling goes down.
Does any bony have a example ?
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Thu, 06/25/2009 - 10:16
  • Hall of Fame,
    Founding Member
Hello Antonio,
have a look here:
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_backup_serial_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1001021
Note:
define interesting traffic carefully to avoid to pay high fees
don't use simple permit ip for the dialer list
Hope to help
Giuseppe
Afragoso2009 Thu, 06/25/2009 - 10:37
I had congifure the remote site
but I am seeing that its not dialing when I put the serial line down even the interface dialer goes up
I ahve the following configuration on the remote router
interface Serial0/0/0
ip address 192.168.253.14 255.255.255.252
ip accounting output-packets
ip accounting precedence input
ip accounting precedence output
ip nbar protocol-discovery
interface BRI0/1/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
interface Dialer1
no ip address
encapsulation ppp
dialer pool 1
dialer string 2601424
dialer string 2601425
dialer-group 1
ppp authentication chap
Giuseppe Larosa Thu, 06/25/2009 - 11:13
  • Hall of Fame,
    Founding Member
Hello Antonio,
your Dialer1 interface should have an ip address: a backup link is still an IP link
it is not possible to route ip traffic over an interface where IP is disabled
in this context you can assign a private ip subnet to the DDR service and you can give static ip addresses to the two sites.
Hope to help
Giuseppe
Dennis Mink Thu, 06/25/2009 - 21:35
  • Blue, 1500 points or more
and make sure you set the admin distance of the static route to 200, otherwise everything will go across you dialer, causing a high telephone bill!
so ip route 0.0.0.0 0.0.0.0 dialer 1 200 (for instance)
Afragoso2009 Tue, 06/30/2009 - 09:10
Hi everybody
I add an IP address to the dialer interface.
But when I put the main serial down the dialing its not happennig :
*Jun 30 16:48:33.693: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.253.1
3 (Serial0/0/0) is down: holding time expired
*Jun 30 16:48:55.393: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/
0, changed state to down
*Jun 30 16:48:55.397: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to dow
n
*Jun 30 16:48:55.397: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to dow
n
*Jun 30 16:48:55.449: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
RT_AGN_ASA#
RT_AGN_ASA#
RT_AGN_ASA#
*Jun 30 16:51:35.393: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/
*Jun 30 16:51:35.453: %LINK-5-CHANGED: Interface BRI0/1/0, changed state to stan
dby mode
*Jun 30 16:51:35.453: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to dow
n
*Jun 30 16:51:35.453: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to dow
n
*Jun 30 16:51:35.797: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.253.1
3 (Serial0/0/0) is up: new adjacency
vmiller Tue, 06/30/2009 - 13:25
  • Gold, 750 points or more
Did you add the static route ?
Have you verifyed the ISDN switch type with the carrier ?
smothuku Wed, 07/01/2009 - 01:20
  • Silver, 250 points or more
Hi below is the config...
End - A :
interface BRI0/1/0
no ip address
encapsulation ppp
interface Dialer1
ip address 10.10.10.1 255.255.255.252
encapsulation ppp
dialer pool 1
dialer caller 2601424
dialer caller 2601425
dialer-group 1
ip route 0.0.0.0 0.0.0.0 192.168.253.15
ip route 0.0.0.0 0.0.0.0 10.10.10.2 200
End - B config :
ip address 192.168.253.15 255.255.255.252
back-up interface bri 0/1/0
interface BRI0/1/0
no ip address
encapsulation ppp
interface Dialer1
ip address 10.10.10.2 255.255.255.252
encapsulation ppp
dialer pool 1
dialer-group 1
ip route 0.0.0.0 0.0.0.0 192.168.253.14
ip route 0.0.0.0 0.0.0.0 10.10.10.1 200
check with your provider about switch type which needs to configures on bri interface.
Satish
Afragoso2009 Wed, 07/01/2009 - 09:00
Hi Smot
Thanks for your help . I put the configuration you sugest but my BRI (End - B config ) its still no dialing whe the Serial goes down
Just to confirm , my switch type is net3
vmiller Wed, 07/01/2009 - 13:11
sounds like your dial string isn't correct. Is this a local call ? which country
see the info on the stuff below, Its pretty helpful:
http://www.cisco.com/en/US/docs/ios/12_1/debug/command/reference/dbdipx.html#wp1017611
Here is a list of supported switch types, Ididn't see yours.
http://www.cisco.com/en/US/docs/ios/12_2t/debug/command/reference/dbftisdn.html
route2null Wed, 07/01/2009 - 19:01
Can you actually make a call over the BRI? Forget the config for the moment and use an interactive command to test. Turn on debug q931 and term mon (Or log con) then issue this command...
isdn test call int b0/1/0 xxxxxxxxxx
xxxxxxxxxx = the number you are trying to call.
View the debug output to confirm its even trying to call.
chinkevi_2 Wed, 07/01/2009 - 21:39
hello,
i think you better first manually test the isdn service before test the backup function.
- under bri interface, you need ppp authentication too.
- you need to send chap username password in dialer interface.
- you need local user database to authenticate remote device.
your floating static would be better this way:
ip route 10.10.10.1 255.255.255.255 dialer1
also, please provide sh isdn service and debug isdn q931 when dialing. Preferably in attachment.
Afragoso2009 Thu, 07/02/2009 - 02:39
Hi team
This is the result off my isdn call teste
*Jul 2 10:40:28.387: ISDN BR0/1/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inact
ive
*Jul 2 10:40:36.387: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jul 2 10:40:36.387: ISDN BR0/1/0 **ERROR**: host_disconnect_ack: Call rejected
cause Temporary failure(0x29) call id 0x8004
chinkevi_2 Thu, 07/02/2009 - 05:11
hello,
we need "sh isdn service" and full debug of "debug isdn q931" from start.
pompeychimes Thu, 07/02/2009 - 06:59
  • Bronze, 100 points or more
You do have layer 1 and 2 right? Post the output from the "show isdn status" command please.
Afragoso2009 Thu, 07/02/2009 - 11:10
Please see in atach what I having now
I am now able to dial , only when I remove the "dialer pool-member 1" on the interface BRI 0/1/0 and put it back again
chinkevi_2 Thu, 07/02/2009 - 14:43
Afragoso2009,
please try to attachment again.
the show command we are after is "show isdn status". my apology, i put in the wrong command before.
chinkevi_2 Thu, 07/02/2009 - 16:31
hello,
the good news is isdn does connect.
the disconnection must be caused by ppp negotiation.
so please test again with "debug isdn q931" and "debug ppp negotiation"
Afragoso2009 Fri, 07/03/2009 - 01:56
Hi Chinkevi
See in attach the ppp negotiation and authentication
But why the dialing only star when I remove the "dialer pool-member 1" and put it back again on the interface BRI on the caller site ?
pompeychimes Fri, 07/03/2009 - 04:46
So it appears the chap process isn't completing because you don't have "username rt-core2-1000 password ******" configured on RT_AGN_ASA and/or you don't have "username RT_AGN_ASA password ******" configured on rt-core2-1000.
Regarding your other problem I don't see (Maybe i overlooked it?) how you are defining interesting traffic. For example do you have "dialer-list 1 protocol ip list 101" and "access-list 101" configured?
James
chinkevi_2 Fri, 07/03/2009 - 04:53
i guess when you reinsert the pool command cause dialer interface up.
but you can just use ping direct to remote dialer ip to bring up the isdn, depends on your interesting traffic setup.
ppp failed in authentication phase and it is 2 way authentication. You can remove ppp authentication in bri and dialer config on both sides, or apply the following on both routers:
local router - username rt-core2-100 password xxxx
remote router - username RT_AGN_ASA password xxxx
int dialer x
! send username/password
ppp chap hostname
ppp chap password
from memory if you don't specify username to send, router will use its hostname as username.
if isdn fail again, check the ppp debug again for CHAP phase to be success or fail. After authentication is the IPCP.
Afragoso2009 Fri, 07/10/2009 - 05:14
Great
I remove the ppp authentication and its work fine now
My question now its how to have the 128 k working? I means both B channel at the same time?
