How to set video bandwidth?
Jun 25th, 2009
Hi, How and where do you set video bandwidth, what is defualt bw settings for vtadvantage and also when using a webcam and cupc? Im trying to figure out where this setting is, what it is and how it might be changed so that we can set up correct video bw in cm locations.
Chuck
parshah Fri, 06/26/2009 - 07:39
  • Cisco Employee,
Video bandwidth is configured in the region's page. Along with audio codec, you choose video bandwidth.
By default its 384 kbps. The max you can have is approx 7068 kbps but for that audio codec needs to be wideband.
If you refer to the Help on the regions page, it should give you more info. Or you can refer to the SRND here
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/video.html
