WAAS Optimized TCP Connections
Jun 25th, 2009
Hi all,
Is there any cli command that gives us an overview of the Total Optimized TCP Connections in the box for that moment ?
Best Regards,
Bruno Petrónio
dstolt Fri, 06/26/2009 - 08:32
  • Cisco Employee,
Bruno,
Show stat tfo
Will give you the basics on the connections going through the box.
Show stat accelerator
Will give you details on connections going through the AOs.
There are sub commands for both of those CLIs.
Hope that helps,
Dan
nchidamb Thu, 07/09/2009 - 13:06
If you are running 4.0.x then 'show tfo conn summary' would give you that info.
In 4.1.x then 'show stat conn optimized' would give you the output you are looking for.
thanks
Nat
