Converting from H323 to MGCP
I am converting from H323 to MGCP. Here is my H323 gateway config:
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
application
global
service alternate Default
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface GigabitEthernet0/0
description Data interface
ip address x.x.x.x 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description Voice interface
ip address y.y.y.y 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
control-plane
voice-port 0/0/0:23
dial-peer voice 10 pots
description 9911 calling
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 11 pots
description 911 calling
destination-pattern 911
port 0/0/0:23
forward-digits all
dial-peer voice 12 pots
description Local calling
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:23
forward-digits 10
dial-peer voice 13 pots
description Naional CND/US calling
destination-pattern 9[0-1][2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
dial-peer voice 14 pots
description Service calls
destination-pattern 9[2-8]11
port 0/0/0:23
forward-digits 3
dial-peer voice 15 pots
description International calling
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 16 pots
description Operator
destination-pattern 90.T
port 0/0/0:23
forward-digits 0
prefix 0
dial-peer voice 990 voip
destination-pattern .
session target ipv4:x.x.x.x
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 999 pots
incoming called-number .T
direct-inward-dial
port 0/0/0:23
telephony-service
srst mode auto-provision none
max-ephones 20
max-dn 40
ip source-address x.x.x.x port 2000
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
MGCP Config:
application
global
service alternate default
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager
no cdp enable
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
mgcp profile default
service mgcpapp
destination-pattern 9T
direct-inward-dial
call-manager-fallback
timeouts ringing 30
max-ephones 36
max-dn 72 dual-line
access-code pri 9 direct-inward-dial
I am looking for expert opinion about the config conversion that will work. Appreciate your help.
Thanks.
Paolo Bevilacqua Thu, 06/25/2009 - 17:35
Is your customer properly informed ?
I hear that sentence used too often as an excuse for poor choices.
