IP Communicator kills network connection - not registering
Jun 25th, 2009
Just trying to run IP communicator, but when running the software it kills complete network connectivity, the PC cannot even ping the gateway!
If I connect as follows, everything works:
PC ->7941-> Switch
If I connect directly, it doesnt work
PC -> Switch.
Switches are outsourced, and they run MARS, nothing in the switch logs.
interface FastEthernet4/0/47
description Data and Telephony host
power inline auto max 7700
switchport access vlan 497
switchport mode access
switchport voice vlan 500
switchport port-security maximum 5
switchport port-security aging time 5
switchport port-security aging type inactivity
spanning-tree portfast
FastEthernet4/0/47 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0023.abea.5ab3 (bia 0023.abea.5ab3)
Description: Data and Telephony host
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input 00:00:29, output 00:00:22, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 24170
Queueing strategy: fifo
Output queue: 0/40 (size/max)
16734076 packets input, 7010128110 bytes, 0 no buffer
Received 25166 broadcasts (74851 multicasts)
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 74851 multicast, 0 pause input
29449800 packets output, 11698729854 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
cs01>sh int fa4/0/47 sw
cs01>sh int fa4/0/47 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 497 (LEGACY-DATA-VLAN-497)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 500 (VOICE-VLAN-500)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Overall Rating: 5 (1 ratings)
Anonymous (not verified) Wed, 07/01/2009 - 08:00
What version of CallManager with service release? Have you enable auto registration on the CallManager?
pepsico_anz1 Wed, 07/01/2009 - 15:11
Version 6.01,
the softphones register perfectly when connected via VPN, or Wireless or daisy chanied with a hard phone, but not when directly connected to our outsources switch.
pepsico_anz1 Wed, 07/01/2009 - 17:02
For anyone who cares, I have confirmed the problem is caused by CDP. When CDP is disabled on the PC's NIC, I no longer lose network connectivity. Now to find out why
resolved: BUG: CSCsm26277
*Mar 8 01:18:53.889 UTC: PSECURE: Install IP Phone 0016.d446.5d34 on interface FastEthernet0/4 on vlan 500
*Mar 8 01:18:53.889 UTC: PSECURE: Read:1891, Write:1892
*Mar 8 01:18:53.889 UTC: PSECURE: psecure_del_addr: Deleting secure MAC address 0016.d446.5d34 on port: Fa0/4
*Mar 8 01:18:53.889 UTC: PSECURE: psecure_del_addr: Delete dynamic secure address: 0016.d446.5d34
*Mar 8 01:18:53.889 UTC: PSECURE: swidb = FastEthernet0/4 mac_addr = 0016.d446.5d34 vlanid = 500
*Mar 8 01:18:53.889 UTC: PSECURE: Adding 0016.d446.5d34 as dynamic on port Fa0/4 for vlan 500
*Mar 8 01:18:53.889 UTC: PSECURE: Adding address vlan 500 0016.d446.5d34 to port-security
*Mar 8 01:18:53.889 UTC: PSECURE: Adding addresses to port-security sub block
*Mar 8 01:18:53.906 UTC: PSECURE: Read:1892, Write:1893
*Mar 8 01:18:54.174 UTC: PSECURE: Read:1893, Write:1894
*Mar 8 01:18:54.887 UTC: PSECURE: Install IP Phone 0016.d446.5d34 on interface FastEthernet0/4 on vlan 500
*Mar 8 01:18:54.887 UTC: PSECURE: Read:1894, Write:1895
*Mar 8 01:18:54.887 UTC: PSECURE: swidb = FastEthernet0/4 mac_addr = 0016.d446.5d34 vlanid = 500
*Mar 8 01:18:54.887 UTC: PSECURE: Adding 0016.d446.5d34 as dynamic on port Fa0/4 for vlan 500
*Mar 8 01:18:54.913 UTC: PSECURE: Read:1895, Write:1896
*Mar 8 01:18:55.894 UTC: PSECURE: Install IP Phone 0016.d446.5d34 on interface FastEthernet0/4 on vlan 500
*Mar 8 01:18:55.894 UTC: PSECURE: Read:1896, Write:1897
*Mar 8 01:18:55.894 UTC: PSECURE: swidb = FastEthernet0/4 mac_addr = 0016.d446.5d34 vlanid = 500
*Mar 8 01:18:55.894 UTC: PSECURE: Adding 0016.d446.5d34 as dynamic on port Fa0/4 for vlan 500
