DMA File Size Error
Jun 25th, 2009
I am running the DMA Export on my CM 4.3 on an MCS-7845. Everything goes correctly, however I get an error stating the
"Staging Directory does not have adequate storage space." I have three drives C: D: E:
C has 35 gb free, D has 60gb free and E has 2GB Free. The directory I choose to use for
the storage was the D Drive, however it appears to be using the C drive to stage.
I receive an error
[09:39:37 AM] [Error] Archive file size is greater than the amount of
available disk space in the staging directory. Check if disk space is
available on storage location.
[09:39:37 AM] [Error] Could not build archive successfully.
There appears to be enough room, however I'd like to find out how much space I actually need, or if there's some database cleanups that someone can reccomend. I have already freed up space on the C Drive by deleting most CDR records from the db.
Thanks!
Rob Huffman Fri, 06/26/2009 - 05:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jeremy,
It almost sounds like this is failing during the pre-DMA BARS backup as the DMA tarball should not be that big (less than 100mB per 1,000 phones). Have a look;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807ee59d.shtml#archive
Hope this helps!
Rob
Tommer Catlin Fri, 06/26/2009 - 06:29
  • Green, 3000 points or more
I just ran DMA on a 4.2 system and my TAR was 350 megs or so. I imported to 7.02 ok. This was for 200 phones.
I think 2 weeks, I ran a 4.2 system also with 1500 phones and it was about 900 megs. Imported to 7.01 ok.
ANyways, my two cents :)
