Bulk Subscribe/Unsubscribe a Service to devices/device profiles
Jun 25th, 2009
I want to subscribe a xml service to 1000 devices and device profiles.
I know how to do it one by one to a device or to a device profile.
Is there any way to perform the task by any bulk type of action so as that I can do it to all the devices /device profiles at a sinle go.
Pranjol
stephan.steiner Fri, 06/26/2009 - 03:11
  • Silver, 250 points or more
For devices, I believe bulk admin allows you to do that.
For device profiles, I'm afraid you're going to have to write your own application.
First you extract the UDP name of all the UDPs you want to update, then you do a getDeviceProfile for each, check if the services already contains the one you want to add, if not, add it, then perform an updateDeviceProfile and repeat.
schemberg Fri, 06/26/2009 - 04:44
... an alternative to Stephans suggestion is to export all DPs with full details. Add XML-Services in csv files and reimport it.
Axel
