How to check port mirroring is working or not?
Jun 25th, 2009
It was configured like this
monitor session 1 source interface Gi2/10
monitor session 1 destination interface
Gi2/9 ingress vlan 1
what does this indiacets?
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Thu, 06/25/2009 - 23:50
Hello Vinoth,
you can check with
sh monitor session
source port is Gi2/10
destination port is Gi2/9 the option ingress vlan1 is more specific
ingress should stand only for the inbund direction on the source port and frames in vlan1.
I tried to look at the command reference but I didn't find this option listed.
What platform and IOS image are you using ?
Hope to help
vinothlb1 Fri, 06/26/2009 - 00:26
I have given the sh monitor session but how to know port mirroring it is working or not.. Is there any link pls provide..?
pompeychimes Sun, 06/28/2009 - 22:30
Look at the device (Sniffer, IDS, etc...) to which your mirroring traffic to.
cisco_lad2004 Fri, 06/26/2009 - 12:16
I concur with James, the only way you are 100% positive is:
1-Check your sniffer is receiving data.
2-Even when you see data, remove SPAN port config to make sure the data you see on sniffer is your session (I usually shut the port I am spanning if its not service affecting). The reason is that I have seen that sometimes sniffer is getting all sort of junk you are not really spanning for, especially when using ERSPAN.
Pushpendra Yadav Thu, 07/25/2013 - 10:55
install Wireshark on your system. Connect laptop on span port and then start capturing Span port traffic. If you see traffic coming from mentioned source then it is working fine.
