WAE Inline Card Error
Jun 26th, 2009
Hi all,
After connect the cables in the inline card, i got this error message in console.
wae#Uhhuh. NMI received for unknown reason 3d on CPU 0.
Do you have a strange power saving mode enabled?
Dazed and confused, but trying to continue
Any ideas ?
Best Regards,
Overall Rating: 5 (1 ratings)
dstolt Fri, 06/26/2009 - 08:26
I have seen this error several times before in different situations. Can you post WAAS version and hardware model?
Dan
b.petronio Fri, 06/26/2009 - 14:23
Hi Daniel,
WAE-512-k9 1G, for Version 4.1.3a.32
After google it, i can found several problems always related with kernel ?!??! and hardware problems .
dstolt Fri, 06/26/2009 - 15:56
Yes,
I have seen it with interactions of older BIOS as well. I would have you open a TAC case on it if it persists. The cases where I have seen it have been resolved in the more recent versions of code.
Dan
b.petronio Fri, 06/26/2009 - 15:59
Many Thanks Daniel,
If the error persists, that's what i will do.
Best Regards,
Bruno Petrónio
