reg ccme
Jun 26th, 2009
We have a 2811 router working with c2800nm-spservicesk9-mz.124-23.bin image .We have also bought a FL-CCME-35 license for CCME.
When the telephony-service command was initialized and checked, the version was CCME 3.3.
How do i know to which version of CCME i am entitled to use and can i download the latest version(CME files) and upgrade to start using it..
regards
Kumar
paolo bevilacqua Fri, 06/26/2009 - 02:44
  • Hall of Fame,
    Founding Member
Latest, is IOS 12.4(xx)T. xx changes almost weekly.
You need to buy a support contract to download, or ask your cisco reseller if they can help.
kumar3880 Fri, 06/26/2009 - 02:54
Thanks for the info...Dowloading is not an issue but i wanted to know that to which version of CCME i can download and USE with my current version of IOS..
regards
Kumar
paolo bevilacqua Fri, 06/26/2009 - 10:30
  • Hall of Fame,
    Founding Member
CME and IOS are one thing. So you upgrade IOS to the get newer CME.
