Device unknow in LMS 3.1
Jun 26th, 2009
hi all,
When I add controllers devices like AIR-WLC 4404-100-K9 in RME this device appears as a unknow. I have checked snmp credentials and it's correct and I have installed device packages but doesn't work. I have checked the device appears in product device support tables too. (http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_device_support_tables_list.html)
Any idea?
The OID of device is: .1.3.6.1.4.1.14179.1.1.4.3
I attach screeshot.
Any idea?
yjdabear Fri, 06/26/2009 - 08:37
Is the WLC running the requisite OS version of 5.0.148.0 or greater that [RME] needs though?
Joe Clarke Fri, 06/26/2009 - 11:04
Make sure you have SNMPv1 enabled on the WLC. It is not enabled by default, but RME will refuse to manage it unless v1 is enabled.
j-fragoso Mon, 06/29/2009 - 02:34
The IOS version of WLC is 4.2.130.0.
Is necessary that snmp v1 is enabled althougth is enabled snmp V2? we have got OID via SNMPWalk from CW.
