06-26-2009 03:25 AM - edited 03-06-2019 06:28 AM
I'm using a VTP configuration on my switches but only the VLAN's name was exported, not the port's configuration
06-26-2009 11:14 AM
That is correct. VTP is used for VLANs, not ports. You can either configure all ports at once with the interface range command or use smartports.
http://www.cisco.com/cdc_content_elements/flash/smartPorts/index.html?NO_NAV
Hope that helps.
