CUPS intercluster sip proxy
Jun 26th, 2009
  • Green, 3000 points or more
Michael, reading your book, it says you need to match the sip proxy domain. I have cups server that is:
asia.company.com (CUPSA)
us.company.com (CUPSB)
Would I need to change SIP proxy on both servers to company.com or can I leave them the way they are?
Thanks!
htluo Fri, 06/26/2009 - 09:20
  • Red, 2250 points or more
The SIP domain has to be the same. Because SIP proxy check the domain in SIP URI to determine where to route it.
If the domains are different, it would be "inter-domain" other than "inter-cluster".
Michael
Tommer Catlin Fri, 06/26/2009 - 09:33
Ok, thanks Micheal. So I should use then company.com for both then, restart the SIP Proxy service.
