Wall Mount cables for phones
khenning
Hello all, I was wondering what kind of cables you use to wall mount your cisco 7911 phones. When we try to use a regular cat 5 cable the RJ 45 end is to big to actually allow the phone to be mounted.
safety2008
Level 4
Level 4
are you using the locking wallmount kit?
I have some installed w/o issue
No we are not. We are just using the wall holes on the phone. We do not require the wall mount kits and prefer not to use them. We also can not use them because a lot of our building have wire mold boxes installed.
