Crypto acl with a deny line for L2L vpn
Jun 26th, 2009
Hi everyone, please i have problems with same l2l vpn with a ASA ver. 7.2 and same checkpoint and i have a deny line y the crypto acl. Is that posible or it coud be same problem related with this?? I don't have maches in this lines.
This is the crypto acl.
access-list xxx extended deny ip 172.0.0.0 255.255.0.0 host VMCPRD
access-list xxx extended deny ip 172.16.1.0 255.255.255.0 host VMCPRD
access-list xxx extended deny ip 10.167.0.0 255.255.240.0 host VMCPRD
access-list xxx extended permit ip 10.167.0.0 255.255.240.0 132.145.0.0 255.255.0.0
access-list xxx extended permit ip 10.167.0.0 255.255.240.0 10.162.0.0 255.255.0.0
access-list xxx extended permit ip 10.167.0.0 255.255.240.0 200.123.188.0 255.255.255.0
access-list xxx extended permit ip 10.167.0.0 255.255.240.0 172.22.19.0 255.255.255.0
access-list xxx extended permit ip 172.0.0.0 255.255.0.0 132.145.0.0 255.255.0.0
access-list xxx extended permit ip 172.0.0.0 255.255.0.0 10.162.0.0 255.255.0.0
Thanks.
Regardss!!!
jliscano Fri, 06/26/2009 - 10:58
Are those IP ranges able to get to VMCPRD hosts? Is that what is happening? I'm not clear on what you mean. But let me give this a shot...
Since this is a crypto match-address ACL, I would remove the deny statements and only allow traffic between the local subnets and remote subnets. Then I would add a deny ACL statement in the ethernet interface. Hope this helps.
evucinovich Mon, 06/29/2009 - 10:30
Hi!!!
Yes, may be I need to be more clear. I need all the trafic to be encrypted except the deny lines but I need that all trafic pass throw the firewall. That's the idea. Thanks a lot.
Regards.
evucinovich Mon, 06/29/2009 - 10:32
The VMCPRD has this ip address 10.162.7.19. Igf you see it is in the interestrin traffic that i declare in the crypto acl.
jliscano Tue, 06/30/2009 - 09:03
Have you defined the crypto acl at the other end to not encrypt 10.162.7.19 to the other IP ranges? Also, I try replacing the name "VMCPRD" on the ACL and replace it with the IP address instead. Since I have not seen a deny statement used on a crypto acl, I hope someone else can assist.
Good luck.
