DMA VIC Warning
Jun 26th, 2009
I have the following warning on a MGCP gateway -
Row: 3 SQL error: -746(4202)
Warning message (Business Rule Violation): This VIC card is not allowed for this gateway, under specified slot position and SlotModule
pkid a797fe10-62e4-40e5-9d74-37b60a80f301 NOT MODIFIABLE
Slot 0
Subunit 1
fkMGCP 80f30444-d40a-4d51-b578-60d34de130b6
tkMGCPVic 10005
tkMGCPSlotModule 10001
BeginningPortNumber
The VIC card is currently working OK, is this something new in CUCM 7.0.1 or is this just a flag and can be ignored?
James
Overall Rating: 4 (1 ratings)
rob.huffman Fri, 06/26/2009 - 07:36
Hi James,
It sounds like you are hitting this bug;
CSCsv37730 Bug Details
Cisco 1760 Gateway: supported VICs differ between 4.x and later.
Symptom:
Errors in DMA process related to Cisco 1760 gateway, reported similar to the following:
MGCPSlotConfig 2008-10-24 21:33:46
Row: 20 SQL error: -746(4202)
SlotModule
Conditions:
Upgrade from Windows version when a Cisco 1760 Gateway exists and is configured with one or more modules that are not available in 5.x or later versions.
Workaround:
None
Further Problem Description:
There is a problem with the configuration files used in Cisco Unified Communications Manager versions for the Cisco 1760. Some entries only appear as valid in version 4.x. Updated configuration files are needed to continue with the upgrade process. Status
Fixed
Severity
3 - moderate
Last Modified
In Last 7 Days
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
5.1(4)
6.1(2)
7.0(1)
Fixed-In
7.0(1.39000.46)
7.1(1.39000.8)
6.1(3.9901.1)
6.1(3.1106.1)
7.0(2.10000.18)
6.1(3.3190.1)
6.1(3.9999.1)
7.1(2.10000.16)
6.1(4.1000.10)
Hope this helps!
Rob
