06-26-2009 08:13 AM - edited 03-06-2019 06:29 AM
Im looking for the password recovery procedure for the ME 3400 series switches. Couldn't find it searching Cisco.com
06-26-2009 08:21 AM
I found it!
Procedure with Password Recovery Enabled
If the password-recovery mechanism is enabled, this message appears:
The system has been interrupted, or encountered an error during initializion of the flash
filesystem. The following commands will initialize the flash filesystem, and finish
loading the operating system software:
flash_init
load_helper
boot
Step 1 Initialize the flash file system:
switch: flash_init
Step 2 If you had set the console port speed to anything other than 9600, it has been reset to that particular speed. Change the emulation software line speed to match that of the switch console port.
Step 3 Load any helper files:
switch: load_helper
Step 4 Display the contents of flash memory:
switch: dir flash:
The switch file system appears:
Directory of flash:
13 drwx 192 Mar 01 1993 22:30:48 me340x-metroipaccess-mz.122-25.EX
11 -rwx 5825 Mar 01 1993 22:31:59 config.text
18 -rwx 720 Mar 01 1993 02:21:30 vlan.dat
16128000 bytes total (10003456 bytes free)
Step 5 Rename the configuration file to config.text.old.
This file contains the password definition.
switch: rename flash:config.text flash:config.text.old
Step 6 Boot the system:
switch: boot
You are prompted to start the setup program. Enter N at the prompt:
Continue with the configuration dialog? [yes/no]: N
Step 7 At the switch prompt, enter privileged EXEC mode:
Switch> enable
Step 8 Rename the configuration file to its original name:
Switch# rename flash:config.text.old flash:config.text
Step 9 Copy the configuration file into memory:
Switch# copy flash:config.text system:running-config
Source filename [config.text]?
Destination filename [running-config]?
Press Return in response to the confirmation prompts.
The configuration file is now reloaded, and you can change the password.
Step 10 Enter global configuration mode:
Switch# configure terminal
Step 11 Change the password:
Switch (config)# enable secret password
The secret password can be from 1 to 25 alphanumeric characters, can start with a number, is case sensitive, and allows spaces but ignores leading spaces.
Step 12 Return to privileged EXEC mode:
Switch (config)# exit
Switch#
Step 13 Write the running configuration to the startup configuration file:
Switch# copy running-config startup-config
The new password is now in the startup configuration.
Note This procedure is likely to leave your switch virtual interface in a shutdown state. You can identify this interface by entering the show running-config privileged EXEC command. To re-enable the interface, enter the interface vlan vlan-id global configuration command, and specify the VLAN ID of the shutdown interface. With the switch in interface configuration mode, enter the no shutdown command.
Step 14 Reload the switch:
Switch# reload
06-26-2009 08:21 AM
It's based on the 3500 architecture so this document should help:
HTH,
__
Edison.
06-26-2009 08:27 AM
thanks!
