ASA Show run command issue
Jun 26th, 2009
Show run does not stop at page break, it goes from beginning to the end in one enter key, thus, I can't see the beginning of the config.It has just stared doing this recently.
kcaskey Fri, 06/26/2009 - 08:48
Use the "pager line xx" command.
Usually 40-60 should work in the 'xx' part depending on your screen size....
Also use PuTTY instead of your terminal program that doesn't allows scroll-back :)
