Boot Cisco 3560
Jun 26th, 2009
I have a 3560 switch, since yesterday is frozen no port links, only the syst led are ligth, when i restart the switch take many minutes because when it finishes loading the .bin say "Done" but starting fresh again, what can i do with this problem?...in this moment is working because after having done 20 times that cycle finally loaded good the config...how can i check for errors?
Leo Laohoo Fri, 06/26/2009 - 16:48
Sounds like you've stumbled into a bug. What IOS are you using?
So are you saying that if you reboot the switch everything normalizes?
