ACS Not installing renewed SSL Certificate for PEAP/EAP-TLS?
Jun 26th, 2009
We recently renewed our SSL certificate through RapidSSL. While attempting to install the new certificate into ACS, I was given the prompt to showing the updated dates, confirmed and installed the new certificate, deleting the old. I restarted ACS, as required, but when trying to enable PEAP or EAP-TLS, I am getting the error "Failed to initialize PEAP or EAP-TLS authentication protocol because ACS certificate is not installed."
The worst part, is that I when I tried to reinstall the old certificate, I am now getting the same problem.
Any suggestions?
Scott Fella Sun, 06/28/2009 - 06:37
How did you perform the CSR.... did you use ACS or OpenSSL? Also, did you verify that the certificate is in the trusted personal folder on the server?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
