Guest-Vlan Restriction
Jun 26th, 2009
I have this scenario and need help
Network with 4 VLAN
How to avoid guess VLAN to communicate with Other VLAN except Internet-VLAN
All VLAN are created on 3560 Switch
Routing protocol : OSPF
Giuseppe Larosa Fri, 06/26/2009 - 10:58
Hello Amin,
the easiest way to do it is using an ACL applied to the SVI that denies access to other Vlans ip subnets and allow all other destinations
I mean an extended ip acl applied
access-list 101 deny ip
access-list 101 permit ip any
int vlan 3
ip access-group 3 in
Other more advanced methods exist but this is enough to create a guest vlan
Hope to help
Amin Shaikh Fri, 06/26/2009 - 11:38
Is it recommended to configure DMZ VLAN on the core Switch or to have dedicated switch and keep it away from LAN.
what security config steps are required if DMZ vlan is configured on core switch
