SRST Call Rollover in Fallback Mode
Jun 26th, 2009
I'm working on a 3825. I have 2 7960 phones in fallback mode. The main ext is 52720. When I make a call from one phone on ext 52723 to 52720 I pickup. Then when I call on a second line 42723 to 52720 it doesn't rollover to 1st rollover which is 42720. It will just ring on 52720 as a call wait. I can make this happen with the call-forward noan statement in the config, but it needs to be busy, not noan. It also needs to rollover and ring forever and not hangup after a timeout. I've tried all sorts of combinations and could use some guidance. This is what I have for call-manager-fallback:
secondary-dialtone 9
max-conferences 24 gain -6
transfer-system full-consult
ip source-address 10.136.64.50 port 2000
max-ephones 336
max-dn 960 dual-line preference 3
transfer-pattern 5....
default-destination 52720
call-forward busy 4....
moh MOH122304.ULAW.wav
Kenneth Mohammed Fri, 06/26/2009 - 11:51
  • Silver, 250 points or more
Try removing the dual-line from the max-dn statement, and then call-forward busy to 42720.
Hope that helped, if so please rate.
