bgp issue urgent
Answered Question
Jun 26th, 2009
  • Purple, 4500 points or more
I have a site that shares the same public block, and at that site I have a route map that sets a metric to higher than our current site. I'm trying to connect to the public side, but I randomnly get there and I know why.
The pertinent parts are:
int s0/1
ip address 6.6.6.1 255.255.255.252
access-list 10 permit 5.5.5.0 0.0.0.127
route-map ADV permit 5
match ip address 10
set metric 100
set community x:x
router bgp 5
network 6.6.6.0 mask 255.255.255.252
network 5.5.5.0 mask 255.255.255.128
neighbor 1.1.1.1 send-community
neighbor 1.1.1.1 route-map ADV out
The problem is that I have a Fatpipe that all of my links come into at my main site. The traffic outbound can go out any one of those links. I realize that when it goes over the second link, it's not allowing me to get to the router and I think it's my route map.
Should I also create:
route-map ADV permit 20
and leave it blank? I don't think the 6.6.6.0 subnet is getting advertised.
Thanks!
John
Correct Answer by Edison Ortiz about 7 years 12 months ago
It is not and your deduction is the correct one.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Fri, 06/26/2009 - 12:47
  • Hall of Fame,
    Founding Member
John Blakley Fri, 06/26/2009 - 12:50
Thanks Edison. I'll be fixing it tonight.
Edison Ortiz Fri, 06/26/2009 - 12:54
  • Hall of Fame,
    Founding Member
Good luck. Routes not matching ACL 10 were being processed by the implicit deny on such route-map. That will always get you :)
