ASA5505 Remote VPN Communication Issue
Jun 26th, 2009
I have an ASA5505 configured for remote VPN connection. It works fine for the two of us who use it. However, I tried to connect another computer from a different location. The connection was made, however it is not able to open a session on our terminal server on the inside. I tried to different users on the router. I did notice that the Verizon router assigns the computer the address of 192.168.1.2 with a gateway of 192.168.1.1. This is the same as the assignment from the ASA in the remote connection IP. Should I change the Verizon router to assign a different IP such as 192.168.100.2? Thanks, Kevin
dsweeny Thu, 07/02/2009 - 07:57
The problem can also be that the xauth times out. Increase the timeout value for AAA server in order to resolve this issue.
For example:
Hostname(config)#aaa-server test protocol radius
hostname(config-aaa-server-group)#aaa-server test host 10.2.3.4
hostname(config-aaa-server-host)#timeout 10
hill.kevin Mon, 07/06/2009 - 05:39
Thanks, I will look at this. I did have the Verizon router changed to 192.168.1.254 and increased the DHCP IP addresses to .50. This worked. Thanks again!
