RME config issue of C4990M
Jun 26th, 2009
LMS Version 2.6
RME Version 4.0.6
we are facing RME config backup issue.
Currnetly running IOS
Please find the error below for cisco C4900M
CM0056 Config fetch failed for Cause: CM0204 Could not create DeviceContext for 1103 Cause: CM0206 Could not get the config transport implementation for Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
Joe Clarke Sat, 06/27/2009 - 18:09
There is no support for a Catalyst 4990 in LMS. What is the exact sysObjectID of this device?
